2 Piece large frame legshield bead
Posted: Tue Dec 20, 2011 3:35 pm
by mawso
Do all pre PE/PX large frames use the same 2 piece legshield beading pls?
Thanks Stu
Re: 2 Piece large frame legshield bead
Posted: Tue Dec 20, 2011 8:11 pm
by vesbrettas
no is the quick answer but it depends on how pre you mean, all sports largeframes came with a 2 piece trim as standard but are all different apart from ss180 and rally which are different numbers but the same shape.
i think the remade cuppini are designed to fit sprint, rally, gtr type frames and then theres another one for sportique,vbb type frames but i think all the cuppini ones need some fettling as they dont fit well, if its a sprint one you want let me know as ive got a new one that i wont be using
Posted: Wed Dec 28, 2011 12:47 am
by mawso
OK thanks for the reply. I've got a set I wanted to identify. I'd hoped they'd all be about the same. Would a picture help?
Posted: Wed Dec 28, 2011 11:19 am
by vesbrettas
a picture may help and if theve got a number on them
Posted: Fri Dec 30, 2011 12:49 am
by mawso
Not sure if these help or not, but I couldn't find any code numbers.
Posted: Fri Dec 30, 2011 12:53 am
by mawso
^^ Looks bent out of shape in places in photo which is a bit weird as they're straight.
Posted: Mon Jan 02, 2012 8:31 pm
by vesbrettas
its a bit hard to say but from the photos i would think sprint type as the curve halfway dosent look to tight
Posted: Wed Jan 04, 2012 10:37 am
by mawso
Thanks for the reply, very helpful!
