hydraulic inboard disc conversion from scootrs
Posted: Sat Mar 28, 2009 3:10 pm
by Werner Amort
any experience?
http://scootrs.com/moreinfo.cfm?Product_ID=1906
it looks nice but how its working?
wich type of rubberseal is used?
Re: hydraulic inboard disc conversion from scootrs
Posted: Sat Mar 28, 2009 3:18 pm
by jimmers
they are a little unit so to speak that fit in the place of the original actuator that goes in the hole
they rely on a very good circlip groove and fitment to be extra safe
there is a little lip seal that make the seal and works very well
if used with a hidden master cylinder you can almost keep the original looks
worth doing but you will need piping and a master cylinder of some description
Posted: Sat Mar 28, 2009 5:34 pm
by Werner Amort
thats what i want, the orginal look for my tv!
as master cylinder i use a TPH cylinder
this cyninders are working very well
for example, the TPH-Cylinder in my serveta
my only fear for the scootrs conversion was the seal
most of the english conversions i have seen use a simple "O-ring"
and not a squarely seal like its used in motocycles...
but if theres a lip seal, everything shut be good...
PS
sorry for my english and greats from italy :oops:
Posted: Sat Mar 28, 2009 6:00 pm
by Knowledge
Your English is great. :D Keep posting from Italy.
Posted: Sun Mar 29, 2009 9:12 am
by Werner Amort
any pictures from the scootrs cylinder?
they have a seperately screw to bring the air out?
there is not much space under the cap...
Posted: Mon Mar 30, 2009 12:31 pm
by stokky
Hi all,
I had a Sccotrs one fitted on one of my bikes. Was OK, but felt was not as sharp at braking than say a TAffspeed converted disk I had.
Did not want to modify original disk in anyway so could convert back if I wanted.
Scooter LoopY John (or one of the other guys on here) does a conversion that just uses the circlip to hold it in.
I have now installed and am using this one in preference to the ScootRS one, as it gives me better braking.
I suspect its due to the larger area on the back of the cyclinder that engages with the disk pad (anyway thats what I put it down to).
Good luck.
Martin
Posted: Mon Mar 30, 2009 2:18 pm
by stokky
check this out, the older style one for Scootrs for $39
http://scootrs.com/moreinfo.cfm?Product ... N=34250413
Posted: Mon Mar 30, 2009 11:11 pm
by Werner Amort
where can I buy the other one?
and Pictures? :mrgreen:
Posted: Tue Mar 31, 2009 3:29 pm
by stokky
sorry cannot remember or find who I got it from.
Best bet is try Knowledge on here, if its not him, he will know where to get them from !!
Good luck Martin
Posted: Tue Mar 31, 2009 6:53 pm
by mark
cs engineering have been making these for close to 15 years or there about
