Porting
Posted: Tue Dec 13, 2011 4:32 pm
by cgt75b
What is the best tool for porting work on a cylinder ?
Thanks
Re: Porting
Posted: Tue Dec 13, 2011 6:29 pm
by paulmgreen
Re: Porting
Posted: Wed Dec 14, 2011 6:54 pm
by cgt75b
Cheers lads nice 1 :wtf:
Re: Porting
Posted: Wed Dec 14, 2011 7:43 pm
by RICSPEED
dont mind them ...little in joke ...your a little vage though ...is the cylinder ally ,cast iron ,ally with steel liner ??
Re: Porting
Posted: Wed Dec 14, 2011 7:51 pm
by Powolotti
are you looking at just porting your cylinder? Then a cheapo Dremel-copy is enough, even if it will take you a wee bit longer.
if you want to do more work go for professional equipment - hang-up engine, flexible shaft, 6mm tungsten burrs, foot pedal operated speed switch, various handpieces, straight and angled for transfers. And this is just the minimum of tools you will need.
Re: Porting
Posted: Wed Dec 14, 2011 10:35 pm
by RICSPEED
so in short pauls answer will probbably be your best bet
