PK forks in an SS90
Posted: Wed Dec 07, 2011 9:45 pm
by wack 63
What sort of job is it to fit them so I can fit an hydraulic brake?
Re: PK forks in an SS90
Posted: Thu Dec 08, 2011 9:30 am
by OzOAP
Straight in.
Front mudguard takes some 'fetteling' and fork stem modifying if you want to use a steering lock.
Posted: Thu Dec 08, 2011 8:22 pm
by wack 63
Thanks for that,I presume the mudguard hole will need squareing to fit the stem and the leg bracket altering which shouldn't be a problem.
Posted: Thu Dec 08, 2011 10:38 pm
by joey
...you need the pk -xl forks with the larger spindle and swinging arm...they go straight in same bearings and length...you'll need to modify the steering lock cut out...and as stated mudguards gunna need a bit of fettlin'...
have a look at proboards small frame forum...don't know how to show a link :mrgreen: there's loads of knowledge on there....
what you up to now? ;)
Posted: Fri Dec 09, 2011 2:39 pm
by jonny snatchsniffer
pk125 forks are what you want if you are fitting a disc, stay clear of xl2 forks as these are threaded all the way up like a t5 so you will need to fettle them of weld on a different stem
have a look here http://davedaniel.proboards.com/index.cgi?
