PX flywheel side roller bearing
Posted: Wed Dec 07, 2011 10:35 am
by byron
how many rollers are in the flywheel side bearing on an '07 PX125
just stripped an engine down after seizures, and this bearing cage had collapsed.
obviously will be replacing the bearing, but until I get a new one, it'd be good to know that none escaped and fell into the rest of the engine as I split the casings, as I wasn't planning on taking it apart any further.
I have retrieved 22 rollers so far...
Re: PX flywheel side roller bearing
Posted: Wed Dec 07, 2011 10:46 am
by Fruitjuice
The crank area is sealed from the rest of the engine (gearbox-clutch) so it would be very difficult for anything to get to the bottom end, unless it finds a way through the clutch side oil seal and bearing...
Posted: Wed Dec 07, 2011 12:27 pm
by byron
yes, but the rollers all fell out as i was splitting the casing, so could have fallen in the gap into the cogs...
Posted: Wed Dec 07, 2011 2:43 pm
by OzOAP
Just counted bearings in 3 engines I have stripped incase there was any variation.
Bad news Im afraid...23 needle rollers :?
Posted: Wed Dec 07, 2011 2:47 pm
by byron
OzOAP wrote:Just counted bearings in 3 engines I have stripped incase there was any variation.
oh no! think I will check the workshop floor first... thanks for taking the time to do that.
Posted: Wed Dec 07, 2011 4:11 pm
by byron
byron wrote:... I will check the workshop floor first...
which is where I found it! :mrgreen:
