Primer nightmare
Posted: Mon Dec 05, 2011 11:38 pm
In my haste to get a panel ready i threw quite a bit (see loads) of filler primer on to 2 low spots on the bodywork. I didnt really let them go off in between coats and then put normal primer over the lot. then left it overnight on the arga ready to flat off next day. Problem is that the 2 areas havent gone off after 2 days. Its like putty you can dig your nail in and then smooth out the mark with your thumb....
Thers no filler under it to react but i dont think its going to go off now after nearly 3 days. The rest of the panel is fine and has flated perfectly. I think im going to have to scrape it clean and fill it with dolphin glaze and start again....
Anyone else had this happen
Ta
sef
Ta
sef
