convert to battery
Posted: Sat Dec 03, 2011 9:58 pm
by ducksta
hi guys i run a t5 classic, i want to fit a battery to run my rev counter and a 12v power point, what do i need to convert my wiring loom etc pics and diagrams appreciated
Re: convert to battery
Posted: Sat Dec 03, 2011 10:33 pm
by phil mcglassup
Good question!!
I've got a PX200 with no battery and think that if I ever have an engine problem at night, I'd end up with no lights whatsoever which to me is dangerous. Even side lights would be better than nothing. I can't help thinking it's a big job to convert it.
Posted: Sat Dec 03, 2011 10:59 pm
by mark
convert it to dc doing the same as we do on lambrettas just check out the dc conversion how to thread
http://scooterotica.org/forum/viewtopic ... conversion
Posted: Tue Dec 06, 2011 4:06 am
by C*NTSPEED
You only need a 5 pole regulater and a bit of know how i did do a guide on the original square tail forum
Posted: Tue Dec 06, 2011 10:09 am
by mark
That's even easier , does it turn it full dc lighting?
Posted: Tue Dec 06, 2011 5:21 pm
by phil mcglassup
Could you please supply a link to the guide you did as I can't find it. I've found one guide but the images were not available.
If not, are there any other guides you could suggest out there for doing the job. My engine is coming out in a few weeks so I might as well convert it while it's out.
BTW, where does the battery fit?
Cheers in advance.
Posted: Tue Dec 06, 2011 8:37 pm
by mark
this is the one i was on about
, can you fit battery in spare wheel as per std vespa?
Posted: Tue Dec 06, 2011 9:27 pm
by C*NTSPEED
Ok roughly as i remember this will only supply power and trickle charge the battery as the engine is running.
Mark it does not effect the lights you need the option you are on about mate
Wire the five pole with the power from stator and power from the battery to the pole on the regulater.. then earth from regulater to to the earth on battery then take the live feed from the regulater to one pole on the 12v socket and run an earth from battey terminal to the other pole i hang another bullet conector of this to feed another scource if needed
I know its a bit sketchy but
Its all comon sense when you step back and think about it
Posted: Tue Dec 06, 2011 9:52 pm
by mark
that is a great way of charging battery for air horns and satnav/cigarette lighter.
what a great site 2 questions and the best 2 answers all in one post
