Unable to start series 2
Posted: Sun Nov 27, 2011 9:25 pm
Hi,
Looking for some advice please.......Just finishing restoring my late li150 s2 and cant get it to start.
I've Added a new 12v electronic ignition kit ( new CDI etc) mb simplified loom.
I've kept the original innocenti handle bar light switch, headset junction box, front and rear light bulb holders and kill switch. Changed all bulbs to 12v ones and replaced front light earth wire to run from bulb holder to gear rod stirrup. Also replaced rear light earth wire for new one.
I am getting a spark and the plug is wet, I've checked the choke is lifting properly as well. I've removed rubber air filter and there is fuel in there and kicked over with the filter removed too, still no joy. so I'm thinking that I'm some how earthing the scoot as the reason for it not starting?!!
In terms of wiring I have
Loom- black, brown (with grey joined with a separate bullet connector) and green.
Switch- blue, red, yellow, White( may actually be grey!?) brown, black, purple and an extra long White wire which splits off on it's own from the sleeving. I'm assuming this goes down to the horn.
Kill switch- green
I've got the blue, red and yellow ( and a White earth) in the bulb holder
In the headset junction I have connected the following;
Loom green with kill switch green
blacks with speedo bulb holder
Loom Brown and light switch brown and purple
White light switch junctioned with a new length of wire down to horn.
So my questions are .....
1. Am I heading down the right route that I'm earthing the scoot as I'm trying to kick over??
2. What is the extra long White wire that splits off from the light switch used for ?
3.if not electrical what other things should I be looking at?
4.It was originally a battery model, are non battery handlebar Light switches different to battery??
Any help appreciated, it's doing my head in!
Kill switch- green
