t5 cruciform
Posted: Thu Nov 17, 2011 7:44 am
by andy1730
i used to have a problem with my t5 jumping out of 3rd so i replaced the cables still had yhe problem so pulled engine apart and cruciform was badly worn have now replaced this with new genuine piaggio one but still having problems i start it and it jumps into gear and stalls is it possible to fit cruciform wrong way round or is this a cable issue :?
Re: t5 cruciform
Posted: Thu Nov 17, 2011 7:57 am
by Guy160
Not possible to fit cruciform the wrong way round on T5's Probably cable adjustment,or the selector box is fitted wrong and the arm inside isnt connected.
Re: t5 cruciform
Posted: Thu Nov 17, 2011 5:37 pm
by goldeneye
worn selector pawl. just replace the whole selector box, it"s less hassle.
Re: t5 cruciform
Posted: Thu Nov 17, 2011 6:56 pm
by vince
As long as you have fitted the flat type that t5s have you cannot fit it the wrong way round. i reckon you might not have picked up in the selector box, but as advised do the selector box they wear as well and cause cruciforms to go.
