Rally 200 engine into bajaj
Posted: Sat Nov 12, 2011 1:04 am
by ScooterLoopyJohn
Hi, new to vespa's . got a 1998 bajaj frame and a 1974 rally 200 engine. what are the snags with fitting the twoi together?
Re: Rally 200 engine into bajaj
Posted: Sat Nov 12, 2011 1:34 am
by goldeneye
should go straight in john. might need a bit of a push and a shove, (sometimes the engine mounts are a bit wide, a couple of mm or so) the wiring, the last PX motor i fitted to a BAJA frame , wired up pretty easy, but i cant remember what i did! it was only one or two wires to swap about engine end. the lad is still riding around on it. i didnt have to change switches or regulator etc. mind you, being indian , ther are a few different models/ changes on the bajaj. (l.sl, classic, retro, retro classic, ml, etc. (etc. isnt a model, its just an etc. :lol: )
Posted: Sat Nov 12, 2011 10:19 am
by rondon
sthil saw, welder, anything can be made to fit :geek: :bigsm: Image
