Page 1 of 2
Piston options for 186cc reed valve cylinder?
Posted: Wed Nov 09, 2011 2:04 am
by ArKaTxU
Hi.
What are the options now to convert a TV175 cylinder to a reed valve?
I need only a piston.
Thanks
Re: Piston options for 186cc reed valve cylinder?
Posted: Wed Nov 09, 2011 7:54 am
by CPH Lambretta
Mitaka ,the same one used in the GT 186 kits
Posted: Wed Nov 09, 2011 5:51 pm
by Stokie
as above
Yamaha RD 350 piston (64mm bore)
Not sure what rod you'd need though - possibly standard 107mm
Posted: Wed Nov 09, 2011 7:42 pm
by bigmuff
Stokie wrote: as above
I have just done a RD350 piston conversion on a SR175 barrel using 60 x 107 crank. I got 3mm taken off base off barrel. I think the TV 175 used a 58 x 116 crank. Would this mean you would need a packing plate? 6mm?
Posted: Wed Nov 09, 2011 11:28 pm
by soullad
Have you a standard TV ( 58 x 116 mm ) crank already fitted Ackba?
Posted: Wed Nov 09, 2011 11:37 pm
by ArKaTxU
soullad wrote:Have you a standard TV ( 58 x 116 mm ) crank already fitted Ackba?
Thank mates!
No Ian, I have the TV barrel but still I dont have the crank.
Posted: Wed Nov 09, 2011 11:40 pm
by ArKaTxU
Are you sure that youtake off 3mm with 60x107?, its possible that you have 60x110?
Posted: Thu Nov 10, 2011 8:26 am
by bigmuff
Yes definately took 3mm off the base of a standard length barrel (101mm). I think if you use a 110mm rodded crank with a std barrel you dont need to remove anything.
I am sure I have a 60 x 107 mec crank. I only bought it earlier this year.
Re: Re: Piston options for 186cc reed valve cylinder?
Posted: Thu Nov 10, 2011 10:21 am
by ArKaTxU
bigmuff wrote:
ArKaTxU wrote:
bigmuff wrote: I have just done a RD350 piston conversion on a SR175 barrel using 60 x 107 crank. I got 3mm taken off base off barrel. I think the TV 175 used a 58 x 116 crank. Would this mean you would need a packing plate? 6mm?
Ok.
Posted: Thu Nov 10, 2011 2:26 pm
by soullad
Admiral - you need to find out what the compression height is for the RD 350 piston. Then you can work out what rod length / crank / cylinder machining best suits your intended set-up and pocket.
