external front suspension
Posted: Mon Nov 07, 2011 4:47 pm
by tonydevon
Greetings, I was wondering where people get the suspension setups that they use on the lambretta forks, the complete shock on the outside, not just the damper
anyone tried the suspension from monkey bikes etc??
I have a set of bare forks and so thought it easier to just go with that setup rather than buy all the bits to go inside the legs etc
will probably make my own links as Im going to be running 15mm axle, unless I find alternative bearings, but at least if I make my own links, I can make sure the bolt for the shock is welded properly, and the axle hole will be full circle.
Re: external front suspension
Posted: Mon Nov 07, 2011 5:17 pm
by Stampede
The monkey bike dampers on a lambretta fork are much too stiff for a good suspension.
Posted: Mon Nov 07, 2011 5:24 pm
by tonydevon
ok cool thanks, any info is good info, so who supplies the kits I keep seeing fitted to peoples scooters?
are they hard on the front end?
I like to have suspension that works.
Posted: Mon Nov 07, 2011 6:22 pm
by CPH Lambretta
Try Lambretta Innovations /Frank Sandersen
Posted: Mon Nov 07, 2011 6:34 pm
by Stampede
CPH Lambretta wrote:Try Lambretta Innovations /Frank Sandersen
Yeah, they don´t use monkey bike ones. They look similar, but are much smoother in damping!
Posted: Mon Nov 07, 2011 10:28 pm
by T5-190
Here you go Tony, these are the ones Frank does. Not sure what they are off originally. Just give him a bell mate.
Posted: Tue Nov 08, 2011 1:55 pm
by tonydevon
aha now they are what Im talking about, seen some chrome ones, but dont like them, they look a little cheap
those looks great
in your opinion, do they actually work?
thanks
just found them on the PM-tuning site, Bitubo basically £200 a pair, bit rich but if they work then I will have to add them to my xmas list LOL
Posted: Thu Nov 10, 2011 9:21 am
by mickdale
do they fit with a standard gp mudguard ok?
cheers
mick
Posted: Thu Nov 10, 2011 10:06 am
by RICSPEED
yes
Posted: Thu Nov 10, 2011 8:05 pm
by T5-190
Tony I can't comment yet on how they handle but Frank has sold hundreds of sets so far. Mick, as Ric says they do fit with a standard mudguard.
