Page 1 of 2
Mismatched Endplates
Posted: Fri Nov 04, 2011 7:57 am
by soulsurfer
I have a casing with no matched endplate but a few other endplates to choose from, is there a shortcut to finding which endplate is the best fit without fitting the gearbox and endplate bearing?
Re: Mismatched Endplates
Posted: Fri Nov 04, 2011 11:31 am
by dapper
Sadly, not really. You need to fit layshaft, loose gears and Xmas tree plus endplate to check all line up and gearbox moves freely. Oh, and plus of course endplate bearing :roll:
Posted: Fri Nov 04, 2011 12:53 pm
by soulsurfer
dapper wrote: Oh, and plus of course endplate bearing :roll:
Yeah, that's what I thought, I couldn't see a way, but you know there's some smart cookies on here that sometimes come up with ingenious ideas :lol:
Probably need to stock up on bearings then :|
Posted: Fri Nov 04, 2011 1:02 pm
by Angry Bloke
Interesting..............
To put your question another way - When a casing is noted as "with matched end plate " what exactly is matched ?
Is it as ,as suggested , assembled with all gears bearing and shims to check all the holes etc line up
or
The machined faces on the underside of the endplate and the machined holes for the bearings are parallel with each other etc
Any ideas ?
Posted: Fri Nov 04, 2011 1:40 pm
by RICSPEED
supposedly the case and end plate are machined together at the same time so all baring faces are in the same position
Posted: Fri Nov 04, 2011 2:13 pm
by Angry Bloke
RICSPEED wrote:supposedly the case and end plate are machined together at the same time so all baring faces are in the same position
Thats what I would have thought too ;)
In which case I would be surprised if the tolerances are very tight ( when concidering the state of some casting I have seen / out of position brake pivots etc)
Therefore as long as the box and tree is correctly shimmed then most endplates will be usable.
Make sense :?:
Posted: Fri Nov 04, 2011 2:34 pm
by sideout
Dead right, "supposedly" line bored. Ever wondered why they're dowelled in position?
Why people sell casings on ebay and separately list the end plate beggars belief! :roll:
Posted: Fri Nov 04, 2011 6:31 pm
by Tosh
I remembered when i bought a brand new 200 from a dealer only to find out that when i put my hub/wheel on there was movement,i replaced the end plate out of my 150 engine,no probs
2 1/2 years down the line but when i told the dealer he said that i should have sent the engine back,so my warranty was void....
Posted: Fri Nov 04, 2011 7:41 pm
by carlos fandango
Posted: Fri Nov 04, 2011 7:53 pm
by Angry Bloke
carlos fandango wrote:http://www.forums.ilambretta.com/viewto ... =2&t=31567
its still working for me :D :D
That settles it for me - Many Thanks :D
