Malossi 210 barrel
Posted: Wed Nov 02, 2011 9:31 pm
by MCH
is this barrel still usable?
it has a small score mark between two of the transfers, what do you reckon?
Re: Malossi 210 barrel
Posted: Wed Nov 02, 2011 10:42 pm
by smiffy1968
I've done thousands of miles on a lot worse barrel than that. Although it was not a full on tuned engine.
Posted: Thu Nov 03, 2011 12:32 am
by joeythescooterboy
I've used worse, a lot worse, just smooth the score over with a bit of wet n dry. It's below the transfers so you shouldn't lose too much compression.
First thing I'd do though is look for what caused it???
Posted: Thu Nov 03, 2011 7:38 pm
by MCH
It was stripped off another engine, piston had tried to hole, but the top and one side had broke off which caused the score I guess, should I use the piston rings from the piston for my new piston or just get new ones?
Posted: Thu Nov 03, 2011 11:20 pm
I'd get new rings fella, it doesn't take much to knock them out of shape and you'll run the risk of getting lots of blow by.
Posted: Tue Nov 08, 2011 2:49 pm
by 225worb
dude thats got loads of use left it, they are pretty robust though the pistons i find crack under the ring piece lands, just polish out the rough edges of the score then stick her back together :fb:
Posted: Tue Nov 08, 2011 9:39 pm
by MCH
cheers fellas
im just collecting all the bits i need to build my malossi 221 monster of a machine, slow progress, but im getting there, just need advice on gearing now as im running an over sized tyre on the back and so need to up gear it,
going to keep the cosa clutch though, buying a milled out basket for it as i know cosas are crap for handling the power im looking for
