Best Way Of Fitting An RGV Mudguard ?
Posted: Wed Mar 25, 2009 8:09 pm
by cranky
Can anyoe suggest the best / ideal way of fitting an RGV mudguard to a set of Lambretta forks ??
Re: Best Way Of Fitting An RGV Mudguard ?
Posted: Wed Mar 25, 2009 9:14 pm
by frank sanderson
Posted: Wed Mar 25, 2009 9:17 pm
by frank sanderson
sos missed a pic
Posted: Wed Mar 25, 2009 10:13 pm
by cranky
Evening Frank - you have a PM.......
Posted: Sun Sep 06, 2009 11:04 pm
by barneypeter
frank can you supply brackets with the mudguard what is cost for both cheers peter
Posted: Mon Sep 07, 2009 12:15 pm
by storkfoot
You don't have to get your forks welded. You could make a bracket from the back (or the front if you wanted) of the damper mount, as the bottom edge of the front part of the RGV sits roughly flush with the mount. You could use the hole that's in the mount and maybe drill another smaller one alongside that you could put a rivet through.
You'd probably need to do this second hole to stop the mudguard moving about.
This is what I plan to do on mine as I have a rebuilt set of forks that have been powder coated
. I've seen others done similarly.
