How to change rear hub bearing in 45 min. No dismantling.
Posted: Mon Oct 31, 2011 11:35 am
Yes! it can be done
After doing the engine rebuild and fitting a substandard indian bearing (unknown name) which had been fitted in a MecEur bag (I suppose by the person who sold me the "project in bits") and blowing 2 seals in no time, I just did not want to undo all the engine and gearbox to change one bearing.
I decided to make use of my bodge-landrover-knowledge and thought, what if I pulled the bearing from outside?
You will need welding skills and equipment, and a decent 2-legged puller. I did not have welding skills nor equipment, so the task was kindly executed by my local bike mechanic.
Be sure to have some protection around the layshaft as temperatures are very high and bear in mind that the alloy can melt, so it needs to be both proper and carefully done
Besides, the heat also makes the bearing removal very easy.
1.- Old (failed) bearing in place. Note protective sleeve of aluminium foil around to protect layshaft against sparks and heat
Uploaded with ImageShack.us
2.- Nuts welded to permit puller do its job properly
3.- Puller in place, baring getting out
4.- Out with the old, on with the new
5.- Used old stock but mint serveta bearing in place
So, 45 minutes, no dismantling
Bear in mind that your scoot can burst up in flames due to a flying spark from somewhere.
Be very careful with that issue. Place plenty of non flammable protection around.
Besides, shimming is critical. Old stock original bearings and RIV and indian bearings did not give shimming problems. Besides original shim was left in the rebuild and that was why I could dispense with the side casing manouvre.
The result was very satisfactory and I'm very pleased doing a 9 hour job in just 45 mins and wanted to share the mother of all bodges.
Happy monday to everyone
Cheers from Spain
Robert
Cheers from Spain
Robert
