Page 1 of 2
Rapido Classic 225 problem?
Posted: Fri Oct 28, 2011 11:15 am
by ArKaTxU
Hi.
I have a friend that has a brand new Rapido Classic 225 and the bore have a small hole inside, where the inlet manifold.
Can you see the pics:
What do you think?
Its usable or will affect performance or piston rings?
Re: Rapido Classic 225 problem?
Posted: Fri Oct 28, 2011 2:07 pm
by coaster
It should be fine, the hole is too small to affect the rings
Posted: Fri Oct 28, 2011 5:40 pm
by rosscla
If it's new he should send it back...why put up with something that's less than perfect if you just paid for it?
Posted: Fri Oct 28, 2011 6:01 pm
by T5-190
Never seen that before hahahahaha.
Posted: Fri Oct 28, 2011 6:42 pm
by coaster
rosscla wrote:If it's new he should send it back...why put up with something that's less than perfect if you just paid for it?
I'd missed the fact that it was new, just assumed it had been sitting around for a while. As rosscla says, send it back and demand a replacement
Posted: Fri Oct 28, 2011 6:48 pm
by sean brady scooters
I,ve seen loads like that but its not really a prob at all .
Posted: Fri Oct 28, 2011 7:27 pm
by shanetv175
it will be if your stud or bolt screws in to far
Posted: Fri Oct 28, 2011 8:49 pm
by rosscla
I can't see how it won't be a problem. Sure, if the threads in the inlet stud produce an absolutely gas tight seal then it might run ok but if they don't then surely at some stage the it's going to leak here.
Either way, that sort of defect should not get through QA to customers, should be sorted at the factory and if it does, it shouldn't make it to the customer the retailer should have sent it back.
Unless people return defective goods we'll keep getting substandard products.
Posted: Fri Oct 28, 2011 8:57 pm
by wack 63
I just chamfer the hole with a Dremil ball cutter then loctite the stud watching how far it goes in.
Posted: Fri Oct 28, 2011 9:14 pm
by bazman
rosscla wrote:I can't see how it won't be a problem. Sure, if the threads in the inlet stud produce an absolutely gas tight seal then it might run ok but if they don't then surely at some stage the it's going to leak here.
Exactly , why turn a blind eye and hope it will be ok , send it back.
