Engine mounts
Posted: Wed Mar 25, 2009 11:23 am
by red ghost
Anyone had a go of making their own?, I'm looking into some soft urethane car suspension bushes that look like they could fit with a little trimming. Just like to hear other experiences.
cheers
frank
Re: Engine mounts
Posted: Wed Mar 25, 2009 11:52 am
by Soulpunk
these are perfect :
http://www.claussstudios.com/id6.html
:biggrin:
Precision Cnc machined outer housing
removable urethane inserts are easy to replace
less than 1/2 the weight of original mounts
urethane has superior :
1. Impact cut and tear resistance
2.Vibration dampening
3. Resilience and memory under repeated flexing
4. Oil and solvent resistance
Simply put the, Clauss motor mount Is the best motor mount available in the world guaranteed,, If you can wear it out I will replace it free !
70 durometer mounts are slightly firmer urethane than stock (original mounts test at 66)
Custom Colors available at no extra cost!
Re: Engine mounts
Posted: Wed Mar 25, 2009 1:39 pm
by jason frost
Still testing to get the right rubber, bit hard at the moment
