Pitted crank
Posted: Thu Oct 20, 2011 7:03 pm
by brucie
Hi there
In the middle of stripping my T5 engine for a rebuild.
Have taken the crank out and found some pitting on it. I am wondering if this will affect it or if it is okay to use. :?:
Pitting on the second pic is where my thumb is.
There isn't any pitting around where the bearings and seals go.
Any advice much appreciated.
Cheers Bruce
Re: Pitted crank
Posted: Fri Oct 21, 2011 10:29 pm
by taff763
Check you casings has it been rubbing?
Re: Pitted crank
Posted: Sat Oct 22, 2011 8:47 pm
by bowers
a rubbing crank would have score marks in it im my experience.
if i seen that in my engine i would only put that in the bin! just hope your sealing pad is ok (inlet on case) if so, throw it, get another and thank you lucky stars! i would also suggest that aint a genuine crank, of its been stood for ages!
Re: Pitted crank
Posted: Sat Oct 22, 2011 8:48 pm
by bowers
actually second thoughts, show pics of it all the way round.
Re: Pitted crank
Posted: Sun Oct 23, 2011 2:04 pm
by goldeneye
looks like its been very rusty, and been cleaned up to put in the motor, if thats the case , the big end bearing will be pitted, and therefore knackered. you could get it re-built with a new rod and bearing, but for the price of a new crank, i"d get a new crank. sometimes things arent worth keeping. chuck it and buy new, it"ll always be at the back of your mind that the heart of your engine is shite.
