30phbh leaking
Posted: Sun Oct 16, 2011 8:53 pm
by shureimage
I've got a problem with my carb it's leaking fuel between the body & the bowl, I've replaced the rubber o ring gasket, but its still weeping, it seems mainly concentrated around the corner beneath the mixture screw.
Any ideas ?
Cheers Dom.
Re: 30phbh leaking
Posted: Sun Oct 16, 2011 9:33 pm
by shureimage
The float bowl is held on with a single bolt underneath, oh & it's a plastic bowl.......
Re: 30phbh leaking
Posted: Sun Oct 16, 2011 10:16 pm
by Andy Pickering
shureimage wrote:The float bowl is held on with a single bolt underneath, oh & it's a plastic bowl.......
Wondered if it was, same as mine..have you replaced the small gasket on the main jet housing bolt which holds the bowl on and make sure when you have seated the o ring correctly with no bits in the groove. not much else that can go wrong really..
