Page 1 of 3
ts1- clubman exhaust
Posted: Sun Oct 16, 2011 6:28 pm
by db67
hi, just wondered if anyone is running an af clubman type exhaust on a ts1,i'm interested to known what their carb & gearing set-up is & what kind of performance they are getting, thanks for any info. db 67
Re: ts1- clubman exhaust
Posted: Sun Oct 16, 2011 8:43 pm
by gtwildcat
am i the only person who wonders what the point is in fitting a high revving kit designed to run with an expansion exhaust and then sticking an old fashioned box exhaust on it when there is lots of low revving performance kits out there that will quite happily perform well with a decent clubman?
Posted: Sun Oct 16, 2011 8:51 pm
by Muppet
if we didn't try these sort of things out then we could never compare; I ran one on a box pipe it was ok; power was good but not as good as an expansion chamber; genuine 70 on a 44mm pipe and 30 Amal.
muppet
Posted: Sun Oct 16, 2011 9:08 pm
by Muttley McLadd
gtwildcat wrote:am i the only person who wonders what the point is in fitting a high revving kit designed to run with an expansion exhaust and then sticking an old fashioned box exhaust on it when there is lots of low revving performance kits out there that will quite happily perform well with a decent clubman?
Nope. But on the other hand, maybe people have tried a few of the other kits, and found them to be pieces of sh it, poorly made, and requiring hundreds of pounds worth of time spending on them to make them work properly.
Cheaper to buy a TS kit.
Not all clubmans are low revving. Mine is going to be built with my RS clubman on it. I don't expect it to be a rev monster. But I do expect it'll sit at 75/80mph all day, pulling 4.6 (or higher) gearing, two up. It might well go faster with an expansion pipe on it. But then it wouldn't sound like a Lambretta, it'd sound like a crosser stuck in second gear.
Posted: Sun Oct 16, 2011 9:17 pm
by gtwildcat
p.s i dont have an expansion pipe on my scooter, just that if i spent that sort of money on a reedvalve high revving kit i would fit an expansion pipe. why not try an avanti kit they have been mainly tested with a 48mm box pipe havent they?
Posted: Sun Oct 16, 2011 9:21 pm
by Muttley McLadd
gtwildcat wrote:p.s i dont have an expansion pipe on my scooter, just that if i spent that sort of money on a reedvalve high revving kit i would fit an expansion pipe. why not try an avanti kit they have been mainly tested with a 48mm box pipe havent they?
When I bought mine, there was no such thing. When I got mine, the option was either an iron barrel (which would have taken over a week to port properly), conical rapidos and maybe a few other none starters.
Posted: Sun Oct 16, 2011 9:45 pm
by soosh
db67 wrote:hi, just wondered if anyone is running an af clubman type exhaust on a ts1,i'm interested to known what their carb & gearing set-up is & what kind of performance they are getting, thanks for any info. db 67
A mate in our club used a 48mm ad Bigbore on his TS and he said it was waste of time and money.Better boxes out there if you wanna use on a TS.
Posted: Sun Oct 16, 2011 10:45 pm
by YAMLAM
soosh wrote:db67 wrote:hi, just wondered if anyone is running an af clubman type exhaust on a ts1,i'm interested to known what their carb & gearing set-up is & what kind of performance they are getting, thanks for any info. db 67
Que: Mick Dale.
who runs a Harry Barlow TS1 230, with either a Avanti clubman or Harry Barlow clubman ( depending on the time of the month)
tell em how it is Ronnie !
Posted: Mon Oct 17, 2011 12:00 pm
by gtwildcat
Harry barlow makes a clubman?
Posted: Mon Oct 17, 2011 1:15 pm
by soullad
He starts with a 48mm Clubman , with its slightly wider diameter tailpipe, and fabricates a stepped header (as he believes that 48mm wide exhaust flange is too wide) so that the downpipe slowly expands in diameter , bit like an expansion until it meets the main box.
