fast flow a px carb
ducksta
hi guys is there any way you can fast flow a standard 24/24 carb, i have the bigger body from sip but it floods all the time tw@7 to start if you dont burn the petrol of before stopping any ideas please scoot 231cc long stroke pollosi
ricalnic
Main scooter: Lambretta GP Monza 225
i've got (SIP) Cosa bowl on mine and larger needle, also Readspeed CNC Tophat.
The feed can also be drilled out, and/or remove the small filter at the inlet.
perhaps you're missing the larger needle to go with the bowl if its flooding all the time ?
ricalnic
LI150
Main scooter: Series 2 LI150
ducksta wrote:hi guys is there any way you can fast flow a standard 24/24 carb, i have the bigger body from sip but it floods all the time tw@7 to start if you dont burn the petrol of before stopping any ideas please scoot 231cc long stroke pollosi
I have one for sale. :D
http://scooterotica.org/forum/viewtopic ... 11&t=18207
ducksta
ime running a 138 main jet b9es plug biscuit brown colour took head off everything looked fine bit lost with it all
C*NTSPEED
am i the only one who has never gad a fueling issue on a 210? ive never had to do anything to a 24mm carb except upjet it???????????????????????????
GEMINI S.C.
BLACK WIDDA'S S.C.
ducksta
mines been a right pain joe still not happy
C*NTSPEED
Have you tried another carb phil?
What about a 24mm flatside or do you still want autolube?
GEMINI S.C.
BLACK WIDDA'S S.C.
ducksta
dont need autolube m8
C*NTSPEED
id look for either a 28 or 30 flatside im sure psn had some phil
GEMINI S.C.
BLACK WIDDA'S S.C.
