Series 2 wiring loom route
andy summers
hi- Rebuilding my li series 2 and cant remember which route the wiring loom takes inside the headset....
does it run down the left side (flywheel side) behind the gear change wheel? I cant get it to sit without rubbing against the gear pulley/cable.
Any advice appreciated.
ta
onefortheroad
Main scooter: Li125 series 2
According to the illustration in vittorio tesseras restoration guide Li headset wiring loom comes in flywheel side, goes under cable guide, under the gearchange rod and back round the front into the connector block.
I've found that the standard electronic loom I fitted was to short to mess about like this and so I just went into the connector block. Gonna locktite em in once up and running as some bullets connectors are loose in the block.
    Users browsing this forum: Google [Bot] and 11 guests
