LI Light Switch Housing Removal
Posted: Tue Mar 24, 2009 7:28 pm
by Bilko
I can't get the light switch housing off. Wellied a load of WD40 into it, but it won't shift.
Also, two screws going into the horncast won't shift.
Any advice please?
Re: LI Light Switch Housing Removal
Posted: Tue Mar 24, 2009 7:48 pm
by J1MS
only advice I can give is soak the screws (with WD40) a couple of times and leave over night the try and warm up the alloy with as much heat as you can get into it, and make sure you have the best fitting screwdriver .....Then cross your fingers and hope it comes out....
Posted: Tue Mar 24, 2009 7:55 pm
by Bilko
Cheers.
I'll have a go again tomorrow with the blow torch.
Posted: Tue Mar 24, 2009 9:36 pm
by lamy150
and try to slightly tighten them,they'll only need to move
a tiny amount then they can be carefully undone
Posted: Tue Mar 24, 2009 10:43 pm
by Ricko
Soaking in diesel works best, be careful if using a flame to heat up metal alloy melts quicker than you think.
IMO heat gun is much safer bet!
Rick.
Posted: Wed Mar 25, 2009 5:49 pm
by Bilko
Managed to get the housing off with mole grips.
Thanks for the help.
