Page 1 of 2
IGNITION 12 ELECTRONIC PROBLEM HELP!!!!
Posted: Sat Oct 08, 2011 1:37 am
by roy242
Hi everyone!
I have a problem with the ignition on my lambretta.
it is armed with: Mugello 186 ..
jl escape krp3
crank TV
(lightened 12v electronic ignition) and the problem here.
the mechanism can not operate it properly.
the problem is as follows:
works properly at low speeds, but around 3000 .. the spark is fired for any place .. and short pins 2 times!
hey changed the pickup for a BGM ... and measured the coils (they are ok)
but the problem persists ..
apparently there are problems because it takes the signal sensor but is very sensitive and is trying to get away for a long regimen of 1500 around the spark lost to 220 degrees when the would have to give away to 180 ° "is the famous spark lost in neutral inferior "and that makes the engine detonates.
Re: IGNITION 12 ELECTRONIC PROBLEM HELP!!!!
Posted: Sat Oct 08, 2011 7:30 am
by mark
Does the 2 metal parts of the pickup line up with the 2 magnets on flywheel ?
Posted: Sat Oct 08, 2011 2:12 pm
by roy242
mark wrote:Does the 2 metal parts of the pickup line up with the 2 magnets on flywheel ?
hi mark!, sorry.... I did not understand the question .. :roll:
Posted: Sat Oct 08, 2011 3:59 pm
by mark
rewound stator plate (5) by mark & anne's photos, on Flickr
line up to the2 magnets on flywheel (at 10 o'clock)
lightened flywheel 1.8kg by mark & anne's photos, on Flickr
Posted: Sat Oct 08, 2011 5:46 pm
by roy242
ok thanks mark!
let's see if I can fix it ..
Posted: Sun Oct 09, 2011 12:06 am
by roy242
the sensor already ran the floor and not doing what happens is that the spark is not lost in the bottom dead.
now I have the captor with the board placed on the bike from the front view with the piston at TDC of the captor tenes chabetero 220 ° or 9 and 20 (h)
the starting point but it has lost the spark across the strip instead of throwing it 180 degrees as it should be the test at 220 ° ..
you can change the position of the platelet (stator)?
Posted: Mon Oct 10, 2011 11:38 pm
by byron
possibly not completely getting what you are writing, but neither would you if I wrote in your language...
but are you asking if the stator can be moved to alter the firing point ?
then yes.
clockwise to retard
anti-clockwise to advance
Posted: Tue Oct 11, 2011 12:12 am
by roy242
Thanks Mark.
In the photo that you posted, is the stator in the correct position? I noticed that the pick-up is at around 4/5 o'clock, is that the correct position or should it be in other?
If it should be in another position, does anyone have a photo showing how it should be?
Posted: Tue Oct 11, 2011 11:29 am
by dapper
No, Roy, that's the correct position around 4-5 o'clock.
Posted: Tue Oct 11, 2011 11:35 am
by dapper
Is Roy saying he is gettinng two sparks per rotation of the flywheel, one 180 degrees from the other?? Seem to have heard summat about this before.
