Mikuni manifold rubber.
Ihateyoubutler
Would I be right in saying that using car radiator type hose is better than using the rubber that comes with the carb (35mm), even though the origonal has a ring that sits in the manifold?
Thanks.
tis what i use
red ghost
Main scooter: lambretta gp150
The radiator hose does seem to be tougher than the pre-made rubbers which tend to split all too easily, plus you can usually get a piece long enough to do at least 2 rubbers for the same price as a normal rubber and you can cut then shorter for better clearance. The real thing probably gives superior air flow because of the divider bar in the middle.
    Users browsing this forum: Majestic-12 [Bot] and 21 guests
