Primer Filler
des
What type of tinner would i need to use with a Upol primer filler, could i use ordinary paint tinners.
I have a tinner i used with some 2 pack paint, can this be used.
crooky
Main scooter: 1960 series 2 li stg 4 175
best to use without thinner ratio 4:1 with hardener it is a bit thick and Ive found the nozzle sometimes needs a clean after the first couple of coats. The problems worst with small 1.2 mm nozzle guns and small capacity compressors. I just turn the fan to spot ie the smallest width of fan. Takes a little more time to cover but goes on thicker too.
To answer your question though Ive used standard gunwash thinners just puting about 10 percent in and had no prolems.
good luck with it
The man who doesn't read has no advantage over the man who can't read
