Wiring Lights: relay question
Posted: Mon Oct 03, 2011 3:34 pm
by ultrarepo
I'm a bit of an electrical numpty so some advice would be welcome...
I'm planning the wiring for the Pathfinders on my S Type and I'm using the Allstyles diagram as a reference point:
My issue is that I want one switch for each light. Where would I add the extra switch? Would I need an additional relay?
I'm also planning a cig lighter / usb socket but I think I'm OK with that
Thanks
Re: Wiring Lights: relay question
Posted: Mon Oct 03, 2011 4:42 pm
by RICSPEED
basicaly wire up as above but fit one light ,then repeat from battery with another relay for the second
Posted: Mon Oct 03, 2011 6:20 pm
by byron
I always thought 85 to earth was the convention on wiring a relay...
not that it should probably matter for the intended use.
Posted: Mon Oct 03, 2011 9:31 pm
by ultrarepo
Thanks: looks like I need to track down another relay...
