rear damper/shocker bush
Posted: Mon Oct 03, 2011 11:32 am
by DaveTomo
I have a spare Meceur rear damper,which is a good damper,give the scoot a once over prior to the IOW and noticed that the rubber bush is coming out.Tried to get it to go back in,couldn't get it to do so,so bought an escort damper,which has been fine.Is there a way to replace the rubber bush? and how? (its only the top one) as I would like to use it again when the escort damper packs in.
Re: rear damper/shocker bush
Posted: Mon Oct 03, 2011 1:52 pm
by Andy Pickering
How have you tried to get it back in..?, my advice would be to press it back in maybe in a vice..but if youve already tried this you could do with knowing someone with a press.
