malossi squish
colourcraft
Hi all
What should the squish be on a malossi 210 . I got a pm head fitted and am getting a reading of 1.95 / 2.00 mm , Is this ok ?
LI150
Main scooter: Series 2 LI150
1.2 - 1.3 would be good
H,POOL GADGE
Main scooter: vespa polini220/gts 300
bear in mind your compression ratio first, this is more important than squish, all be it squish is a good thing, what compression as your pm head been reprofiled to, then you could do a volume test and then adjust the squish, too much compression creates heat, detonation, effects top end and over rev
    Users browsing this forum: Google [Bot] and 33 guests
