Difficulty finding neutral
Astroboy
Main scooter: Lambretta GP 200
When slowing to a stop, I have difficulty finding nuetral on my S1. Often end up standing at the lights in 1st or 2nd holding the clutch in -not good I know.
When I hit the kill switch I can easily rock the bike back into neutral, and any speed over 10 k's per hour, it's easy to find neutral. What's this a symptom of?
cheers
A.
bristolmod
worn selector rod and bush
worn tie bar rod
badly adjusted cables
worn gear linkage
Scootering since 1968.
Magalluf
Clutch Drag
there is a bit in Scootering Nº303 September page 104 which explains it.
Steve
TS1-200
Magalluf wrote:Clutch Drag
Steve
Yes, I had that problem, adjusting the clutch cured it.
Keep on keepin on
    Users browsing this forum: Amazon [Bot], Google [Bot] and 4 guests
