dismantling Inboard disc
Lor@n
Hello,
Yesterday I tried quickly to take apart an inboard disc,
so axle, disc brake lever removed, but still can't get hub and back plate apart.
I don't know how it's made inside, so do I need to remove something else ?
Thanks for your help.
http://lambrettiste.free.fr to get a FREE proper timing disc --> http://lambrettiste.free.fr/documents/f ... gradue.pdf
"A tidy shed is a sign of mental disorder"
the disc needs to come off with the back plate and thats held on with 3 dowls be very carefull if you tap the disc as it can cause the windows side to crack around these 3 lugs plenty of wd40 on those dowls and soak over nite
Lor@n
thanks I'll give it a try.
just tap the disc with a brass bar very close to the lugs work your way round short gentle taps and WD40
    Users browsing this forum: No registered users and 23 guests
