where does this go...?
rebuilding a vespa engine for the first time...
but where does this washer go ?
it was in the tub with oil pump/drive bits, so am thinking it goes on the shaft on casing between the driven gear and the circlip...
it's a PX200E
i should've paid more attention when I stripped it down, which was months ago... :oops:
thanks
vesbrettas
yes it goes on that shaft there sould be 2 ofm them one each side of the gear
cheers, the other one was just a plain washer, without the shaped inner, but it had been on there, witness marks from the circlip
it all seems to fit and turn fine
thanks for the reply
