Page 1 of 5
Kawasaki 240cc Conversion
Posted: Mon Mar 23, 2009 8:49 pm
by mawso
After stripping a friends motor we've discoverd it's a 240cc Kawasaki conversion. The piston is 71mm (is that an oversize?) and the rings were worn so they've been binned.
It's an original piston and he needs a set of new rings...can you still get them?
Cheers Stu
Re: Kawasaki 240cc Conversion
Posted: Mon Mar 23, 2009 8:55 pm
by davidblythe
71mm is standard size for the H2
Be easier to buy a Wiseco H2 piston and rings, wiseco ref no 423M07100OEM
rings are ref 2795CD which is commonly used on wiseco 71mm 2 stroke pistons
OEM Kawaski H2 stuff is rocking horse manure unless you can find rings from another piston to suit
Posted: Mon Mar 23, 2009 9:36 pm
by mawso
David...thanks the for the codes. The rodeye on the 60mm crank is 16mm will the Wiseco be the same?
Posted: Mon Mar 23, 2009 9:40 pm
by davidblythe
yes 16mm
Posted: Mon Mar 23, 2009 9:50 pm
by mawso
Ok good news, thanks for that. Can you recommend a supplier or anywhere that can do a discounted rate?
Cheers Stu
Posted: Mon Mar 23, 2009 10:05 pm
by davidblythe
http://www.wiseco.co.uk/
vic eastwoods down paddock woods brands hatch
about £100
Posted: Mon Mar 23, 2009 10:43 pm
by byron
if you do just want to go with just changing the rings and it is an oe kawasaki piston it's worth trying here : https://www.z-power.co.uk/merchantmanager/
the kawasaki pistons need repegging, but the wiseco items don't.
I've been looking for a 71mm 423M07100 wiseco piston for my big block build with no luck, although i didn't know david's brands hatch suggestion.
ended up getting a first oversize 423M07150, which is not ideal, but fine for my needs.
if you mate's does need a rebore and you get hold of a new 423M07100 kit, I'd swap it for mine, all BNIB.
any more info on the spec and how it rode would be useful as I am still at the collecting bits together stage of my build.
Posted: Mon Mar 23, 2009 10:52 pm
by davidblythe
wiesco doesnt need repegging for piston ported engine
presume you outbid me on ebay last night for that piston :cry:
Posted: Mon Mar 23, 2009 10:54 pm
by davidblythe
h2 piston is used in a jetski 475cc Big Bore Kit
Posted: Mon Mar 23, 2009 11:01 pm
by byron
davidblythe wrote:wiesco doesnt need repegging for piston ported engine
as I wrote :smug:
davidblythe wrote:presume you outbid me on ebay last night for that piston :cry:
yep, that was me :mrgreen: it was a complete bargain til the last few minutes, still happy with £63
