Oxidisation
Posted: Tue Sep 20, 2011 10:04 am
by Doom Patrol
Picked up a sound rear hub at the weekend. It was quite heavily oxidised though. At the moment I've gone over it with a wire brush and because I won't be using it immediately I have sprayed it all over with WD40 which I'm hoping may prevent any more corrosion. What's the best way of tackling it?
Re: Oxidisation
Posted: Tue Sep 20, 2011 5:19 pm
by WINTERMODEL150
Hi,I would get it blasted then powder coated and see what you have left ,you can then flat down high build primer the hub, then re- flat it down and wet spray ,all depends how fussy you want to be I suppose.
Dean
Re: Oxidisation
Posted: Tue Sep 20, 2011 8:29 pm
by shanetv175
there is a 2 part mix called alachrome (not spelt right but thats how it sounds ) remove all oxidisation apply (spray bottle or cotton wool soaked) on till it goes a lovely gold coulour and wash with water and then paint when dryed off ps be careful of the cotton wool as it drys out it can go on fire on its own (there is a big word for that but cant spell it )
Re: Oxidisation
Posted: Tue Sep 20, 2011 8:46 pm
by Doom Patrol
Thanks for the info guys. This sounds like the stuff you were talking about Shane.
http://www.bryonymetaltreatments.mfbiz. ... 4520434833
Re: Oxidisation
Posted: Thu Sep 22, 2011 1:26 pm
by Piatti
Coat with Ankorwax...
Re: Oxidisation
Posted: Thu Sep 22, 2011 7:20 pm
by shanetv175
Doom Patrol wrote:Thanks for the info guys. This sounds like the stuff you were talking about Shane.
thats the stuff when i worked on aircraft we used a lot of it do your head set and horn cover as well
