what piston and head
Posted: Wed Sep 14, 2011 8:49 pm
by mark
i have aquired a genuine 64mm sr kit,what piston is recomended for this considering i am going to run a 22 jetex and original under kickstart fresco?
i also need this to be a low compression motor so need ahead to go with it or who do i use to reprofile a 150 one .
thanks in advance
Re: what piston and head
Posted: Wed Sep 14, 2011 9:03 pm
by storkfoot
Hi, Mark. I ran a Deanspeed one when my SR barrel was first taken out to 64 but the rings wore the bore out really quickly. After MB tuned the barrel, I ran a Racetour 65mm for something like 7 or 8000 miles without any problems. MB matched the head to the piston. As far as I know the Racetour is still in the engine.
My underkick fresco was well suited to the tune and the TM24 Mikuni
And what project is this for, mate?
Posted: Wed Sep 14, 2011 9:08 pm
by mark
cheers paul but i want cheap and cheerful tbh its for the skelly so its not going to get a lot of use
Posted: Wed Sep 14, 2011 9:44 pm
by byron
mark wrote:... cheap and cheerful...
http://www.ebay.co.uk/itm/LAMBRETTA-GP- ... 1c1ecc48d7
not from this seller, but this is of the type I fitted in Tim's bike, seems to be going fine...
Posted: Wed Sep 14, 2011 9:50 pm
by mark
will call corrado tomorrow
cheers mate
Posted: Thu Sep 15, 2011 3:34 pm
by soullad
suzi piston kits from Beedies only 39 quid. Quality rings and 4 oversizes .. but I'm sure you know this already. The 2nd incarnation of the enduro racer used this set up with a 25mm phbl and under kickstart fresco, ran great.
Posted: Thu Sep 15, 2011 4:54 pm
by mark
Cheers ian but I don't want to top and tail or redox my crank so as I said I want to keep it simple and plug and play
