Brake light
Posted: Mon Mar 23, 2009 6:19 pm
by mickeyb
just noticed the back brake light is not working then i noticed there is no wire connected to the switch under the hydraulic cylinder(disc brake)after a re-build,lukd inside the headset at the wiring loom,all wires are connected but is there a certain colour that was connected by mistake?...Thanks
Re: Brake light
Posted: Mon Mar 23, 2009 8:46 pm
by noggin1969
Wiring to the front or rear disc ?
Re: Brake light
Posted: Mon Mar 23, 2009 11:55 pm
by mickeyb
front please
Re: Brake light
Posted: Tue Mar 24, 2009 12:03 am
by sean brady scooters
usually you would have two terminals on micro switch under front brake lever.............
simply make up two wires to run from this and link in to rear brake switch............
