Carb Filter recommendations
des
I want to fit a carb filter to a 35mm Mikuni TMX carb on a TS1, i will be cutting a hole in the panel, what filter would you recommend.
Cheers Des
skidmark
LTH manifold, Evergreen hose, Ram Air filter.
No hole required in side panel, works perfect ;)
    Users browsing this forum: Google Adsense [Bot], Semrush [Bot] and 3 guests
