Decent reliable Imola carb rubber.
Posted: Mon Sep 05, 2011 8:57 pm
by 10 inch Terror
Hi all, as the title suggests can anyone recommend one? Its for the standard metal inlet which is 35mm in diameter and i'm using a 28mm Mikuni which has a 32mm outlet. I'm currently using a scootrs one but i'm not that confident with it. Any suggestions would be most welcome. Thanks Pete
Re: Decent reliable Imola carb rubber.
Posted: Mon Sep 05, 2011 10:59 pm
by Monty
I'm using the LTH manifold that has the bolt on rubber so one less pipe clip to worry about. Not much help sorry
Posted: Tue Sep 06, 2011 6:06 pm
by Maz
I have recently swapped to a Charlie Edmunds inlet.
Posted: Tue Sep 06, 2011 8:50 pm
by Train Driver
Maz wrote:I have recently swapped to a Charlie Edmunds inlet.
pictures, performance update are you saying your scooter is now quicker than mr edmunds ;) ;)
