Kawasaki dampers?
Posted: Sun Mar 22, 2009 10:46 pm
by sydduckett
Looking for a set of kawaski dampers plus weld on bracket setup. any advice on best place to get these. Seen some 2nd hand ones for £80, any where that sells them cheaper?
Saw this link
http://www.motorbikepartsdirect.co.uk/p ... pers/2048/ would these fit?
Cheers chaps
sef
Re: Kawasaki dampers?
Posted: Sun Mar 22, 2009 10:52 pm
by mark-b
Readspeed do them and have them on ebay at the mo... 350168580017
Posted: Sun Mar 22, 2009 11:40 pm
by J1MS
John used to do the best brackets for the Kawasaki dampers, remade bottom screws (wider) and quality weld on top brackets. sold them as Scooter Loopy when I bought mine. Im not sure if hes still making them, but if he is get a set....
Posted: Mon Mar 23, 2009 12:41 am
by sydduckett
have sent Jon at scooterLoopy a email re the brackets, any links for competetive priced Kwaka dampers?
Ta
Sef
Posted: Mon Mar 23, 2009 5:43 pm
by Knowledge
Sef,
Are you sure you want Kwacka dampers? They look trick, but you don't want damping on compression, only on rebound. When you go over a bump, you want the springs to absorb the bump without restriction, and then you want the damper to resist the springs pushing the fork-links straight back down again (or else you get a pogo affect). This is why standard dampers can be compressed with ease, but are hard to pull apart again.
Kwacka dampers apply equal damping in both directions.
Martin
