advice on crank
Posted: Fri Sep 02, 2011 7:49 am
hello , wondered if anyone could recomend a company to send my af crank to check if it is twisted and if so can it be rectified , had afew problems coming back from the iow and it has been said the problem could be a twisted crank . symptoms were went to the iow no problem rode around almost never skipped a beat . my trouble started on the way back to newbury . symptoms were , after giving it some welly coming back the scooter just suddenly died , after changing cdi ( varitronic ) it had time to cool and started although compression seemed a bit harder . so off we set on our journey at a steady pace and all was fine.so after a few miles i tried to open it up again but as i increased the rev te scooter started to judder as if no fuel was burning off . managed to get home ok and put the old cdi back on which is ok so assume something else caused this could it be a blown gasket on the head do you think
kind regards
james
sorry forgot to say its a home built af classic rapido 225 with jl3 28mm phbh carb and varitronic ignition
kind regards
james
