rubber splits
Posted: Thu Sep 01, 2011 4:29 pm
by roadrunnerian
hi i have a ts1 225 with a mb inlet manifold which had an amal 34mm mk2 carb i switched carbs to a mikuni tmx35 i kept the inlet manifold. now when i go after ten miles the rubber splits on the manifold side and seems to catch the engine mount any ideas of stoppping it thanks
Re: rubber splits
Posted: Fri Sep 02, 2011 7:52 pm
by Tosh
Hi Ian,
Have you got the off center cones in that will take the engine a tad lower as to give you more clearance for your manifold and engine mate,also if you have not sorted a new rubber yet nip to my place or get intouch and check this tubing i have.
Paul
Re: rubber splits
Posted: Fri Sep 02, 2011 9:48 pm
by roadrunnerian
thanks for the reply Paul m8 is the tube you have 40mm id m8
