Can you put 100 x 90 x 10 on normal std rim
Posted: Thu Sep 01, 2011 8:10 am
by boxofbits
Can you put 100 x 90 x 10 on normal std rim its on a wide one at the moment but rubbing against casing
Re: Can you put 100 x 90 x 10 on normal std rim
Posted: Thu Sep 01, 2011 8:19 am
by soulsurfer
Yes, it will give better clearance over wider rims such as ScootRS tubeless too.
Posted: Thu Sep 01, 2011 11:02 am
by Craig H
I have Swalbe Raceman 100x90 on rear no problems so far
Posted: Thu Sep 01, 2011 11:20 am
by Andy Pickering
you can also get a spacer from Mb to eradicate this problem and keep it on the wide rim.
