Page 1 of 2
mugello bogs
Posted: Mon Aug 29, 2011 5:15 pm
by idc1967iow
My muggy 186 is very boggy when pulling away ,seems to run out of puff in top even on slight hill.Using a 26mm phbh ,electronic ,ram filter,timing set to 19,it seems like it is carb related,112 main x7 needle 2nd top,any ideas please.
Thanks Ian :fb:
Re: mugello bogs
Posted: Mon Aug 29, 2011 6:35 pm
by byron
probably more info needed...
other carb spec eg atomiser, slide
pipe ?
gearing ?
did it run ok before ? or has it always run so ? changed anything on the engine?
when you do get it running cleaner, I would knock the timing back at least a couple of degrees
Re: mugello bogs
Posted: Mon Aug 29, 2011 7:38 pm
by idc1967iow
Yes sorry av264,ancillotti sito pipe, 45 slide,standard li 150 3 gearing ,air screw 1 turn out,53 pilot,i have changed main jets from 106 to 112,just seems worst around town ,never been the smoothest at low throttle ,4 strokes?.
Re: mugello bogs
Posted: Mon Aug 29, 2011 10:42 pm
by red ghost
Which version Mugello? What crank, any packers, altered ports?
Re: mugello bogs
Posted: Tue Aug 30, 2011 10:15 am
by stew
idc1967iow wrote:Yes sorry av264,ancillotti sito pipe, 45 slide,standard li 150 3 gearing ,air screw 1 turn out,53 pilot,i have changed main jets from 106 to 112,just seems worst around town ,never been the smoothest at low throttle ,4 strokes?.
Tried an x13 needle?
Re: mugello bogs
Posted: Tue Aug 30, 2011 4:24 pm
by goldeneye
what gear box and sprockets have you got fitted?
Re: mugello bogs
Posted: Tue Aug 30, 2011 6:13 pm
by idc1967iow
Standard li 150 series 3 gearbox & sprockets.
Re: mugello bogs
Posted: Tue Aug 30, 2011 6:55 pm
by CPH Lambretta
Re: mugello bogs
Posted: Thu Sep 01, 2011 11:07 pm
by Timbo
i've had similar recently and there was a big crack on the u bend. Check it out.
Re: mugello bogs
Posted: Fri Sep 02, 2011 6:49 am
by idc1967iow
Would it be worth changing front sprocket on a muggy set up ?
