Calling Lambretta LD epicyclic kickstart experts
Posted: Thu Aug 25, 2011 5:11 pm
Hi all,
I hava a problem with my MKIII LD150. The so called epicyclical kickstart is separated from the engine by an o-ring (marked n° 54 on the drawing) because bevel n°51 is lubricated by the engine oil.
So all the rest of the kickstart mechanism is lubricated by grease you can add before closing and refill through greaser n°25.
My problem is that the oil keeps coming in the greased part of the mechanism. I already changed o-ring twice but still oil coming through i think the 2 bronze bushings around wich the bevel revolves.
Does someone remakes these?
Could it be something else? What do you think?
Thanks,
S
a
m
link to the file on scooterhelp:
http://www.scooterhelp.com/manuals/LD_D ... page29.jpg
Thanks,
S
a
m
