TS1 BAD STARTING
Posted: Tue Aug 23, 2011 11:11 am
by roadrunnerian
HI MY TS1 IS A BAD STARTER FROM COLD WHEN STARTED ITS FINE ANY IDEAS PLEASE THANKS.
Re: TS1 BAD STARTING
Posted: Tue Aug 23, 2011 11:17 am
by Andy Pickering
need a bit more info tbh..carb set up and so on..
start with a simple one, check your choke is working correctly ie fully opening then check plug is in good condition and is gapped correctly ie.
Posted: Tue Aug 23, 2011 11:38 am
by drunkmunkey6969
Posted: Tue Aug 23, 2011 6:04 pm
by roadrunnerian
HI
I HAVE A TMX 35 CARB JL3 EXHAUST AUGUSTO 7000 AND AN AF LIGHTENED FLYWHEEL.
Posted: Tue Aug 23, 2011 6:19 pm
by the-brickie
At a guess I'd say its the af flywheel.
What stator?
Posted: Tue Aug 23, 2011 6:21 pm
by Andy Pickering
could do with choke jet size so other tmx users can compare with what there using, first port of call for me would be to make sure the choke fully opens..
Posted: Thu Aug 25, 2011 9:42 am
by roadrunnerian
sorted checked the choke found it needed adjusting started 2nd kick thanks for the help
Posted: Thu Aug 25, 2011 9:46 am
by Andy Pickering
roadrunnerian wrote:sorted checked the choke found it needed adjusting started 2nd kick thanks for the help
Great news..always start with the simple things first..
Posted: Thu Aug 25, 2011 10:44 am
by drunkmunkey6969
No, its definitely a dodgy cylinder.....just post it out to me and i'll look after it for you.
