Page 1 of 2
Casing Disaster
Posted: Mon Aug 22, 2011 9:58 am
by nellyboyo
Anybody else has this happen ???
And any idea why ??
I did have the engine apart to replace the rear hub bearing and seal a couple of days ago but it kicked over fine . Then yesterday this ???
Re: Casing Disaster
Posted: Mon Aug 22, 2011 10:04 am
by RICSPEED
this is why the later cases had the ribs in this area ...you dont say if you had high comp head ,kit barrel ctc
Re: Casing Disaster
Posted: Mon Aug 22, 2011 10:08 am
by nellyboyo
Yes I do, its a long stroke mugello with a reed valve . Not sure what the comp ratio is but it is a monster to kick over. So thats just progessive stress failure is it ???
Re: Casing Disaster
Posted: Mon Aug 22, 2011 10:12 am
by RICSPEED
yes ...as i said it was why later casings were modified
Re: Casing Disaster
Posted: Mon Aug 22, 2011 10:30 am
by nellyboyo
OK , Cheers .
Its a series 3 block with a S2 side casing in my Series 2 .
Am I right in thinking I`ll have problems with the kickstart hitting the floor if I put a Series 3 casing on it ?
Re: Casing Disaster
Posted: Mon Aug 22, 2011 11:08 am
by fred
no,just fit later sidecasing,with s2 kickstart lever
Re: Casing Disaster
Posted: Mon Aug 22, 2011 11:26 am
by nellyboyo
Cheers for all the help lads
Re: Casing Disaster
Posted: Mon Aug 22, 2011 2:06 pm
by Doom Patrol
That's fine. But you do realise the kickstart won't then stop against the casing. So you'll either have to lengthen the tongue or use a later S3 kickstart and bend it to suit.
Re: Casing Disaster
Posted: Mon Aug 22, 2011 2:09 pm
by RICSPEED
Doom Patrol wrote: lengthen the tongue.
do what he said ;)
Re: Casing Disaster
Posted: Mon Aug 22, 2011 8:35 pm
by Supereibar
Has anyone else notticed the "3" on the casing?
Read here:
http://scooterotica.org/forum/viewtopic.php?f=7&t=17615
