Drive side bearing change?
Posted: Sat Aug 20, 2011 9:48 am
by phil23fair
I'm just about to fit a new crankshaft. I know I've got to fit a new mag side bearing, but is it necessary to change the drive side bearing? The one that is fitted is an SKF and has only done about 3000 miles. Can I just replace the oil seal and halite washer? It's not the cost of the bearing, it's having to drop the engine out to replace the bearing.
Thanks
Phil
Re: Drive side bearing change?
Posted: Sat Aug 20, 2011 11:07 am
by Supereibar
Hello Phil, you dont have to drop the engine to replace the bearing mate, I do that on the floor without problems, you need a decent driver to do the job and it shouldnt be a problem.
However if you installed that bearing, and its life has been controlled by you yourself, I wouldnt mind leaving it. In fact, if it has been well taken care of and hasnt been abused I see no reason to replace it. Just replace the seal as that will not hurt at all.
All the best,
Jaime
Posted: Sat Aug 20, 2011 11:58 am
by byron
^whs
Posted: Sat Aug 20, 2011 12:03 pm
by phil23fair
Jaime,
Thanks, I did install the bearing and it hasn't been abused but I will give it a go replacing it with the engine in.
Phil
Posted: Sat Aug 20, 2011 12:05 pm
by bristolmod
if it ain't broke then why fix it????..................you know what will happen.
I'd do as Jaime says- leave it and simply change the seal
Chris
Posted: Sat Aug 20, 2011 1:25 pm
by WINTERMODEL150
Hi,when you knock out a crankshaft it puts excessive force on the inner bearing track of the driveside bearing thus shortening its life,i always change the bearing regardless,its a lot of work if you take a chance and it fails.
Dean
Posted: Sat Aug 20, 2011 4:08 pm
by Supereibar
What Dean says its a different story, if you have suffered a crank seize then replace it. I didnt know if you where upgrading the engine or doing recovery from a massive seize.
J.
