upjet or down jet
Posted: Thu Aug 18, 2011 3:12 pm
by ts200
i've got a ts1 200 that i've always run with a 34mm amal and got sick of filling up all the time so i bought a 30mm mikuni off a lad on here who had it on his ts1 225 and said it was running fine
on mine it runs a lot smoother and not so juicy which is what i wanted
the only problem is when i give it full throttle it just burbles away and doesn't accelerate,
when i close the throttle to about 1/2 to 3/4 it accelerates well
do i upjet or downjet or muck about with the needle?
the set up is
ts1 200
jl 3 pipe
this is the carb jetting spec sheet he gave me
powerjet blanked off
float valve 3-5
float 2-10
main jet 280 (it was a 290 when i got it)
pilot jet 30
slide 4-0
atomize/tube:622/0-4
needle: 5EL68
clip position2nd from top
mixture screw 2 turns out
any help would be appreciated
Re: upjet or down jet
Posted: Fri Aug 19, 2011 8:27 am
by Diablo
All I can say is that 280 will be on the rich side so don't be afraid to try weaker main jetting.
Posted: Fri Aug 19, 2011 11:49 am
by OzOAP
Fit a camLam PJ.
Gives a lot crisper bottom end.
This is what my TS runs
Main Jet: 200
Needle: 5EL68
Slide: 45
Pilot: 30
Float seat: 3.5
Posted: Fri Aug 19, 2011 6:11 pm
by ts200
Diablo wrote:All I can say is that 280 will be on the rich side so don't be afraid to try weaker main jetting.
Thanks diablo, ive got a 260 i'll give that a go. Oz whats with the sensible answer? Not one lambwetta remark, you've let me down, yourself down, now go and stand in the corner til after the isle of wight freakshow.
Posted: Sat Aug 20, 2011 8:10 am
by Diablo
:lol: :lol: I am getting worried about Oz myself
upjet or down jet
Posted: Sun Jan 22, 2012 3:19 am
by Dryballs
I run about a 220 main and 17.5 idle on my ts1
