mismatched flange to case
Posted: Wed Aug 17, 2011 5:56 am
trying to figure out what flange i have.
the case is an early Sr2 and i thought the mag flange was original to it but I could be wrong.
when the flange is seated the transfer port in the case sits proud relative to the flange on all 3 walls of the transfer.
i'd rather not grind down the case to blend it so i just want to confirm that what i have isn't the original flange so i don't end up buying an identical one.
also, unrelated. the case cover had a "4" stamped above the k/s shaft. just curious if it's common. the scoot has had a bodged life so it wouldn't surprise me if it's "custom"
Thanks,
graham
Thanks,
graham
